Archtop side tensioners http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=56540 |
Author: | Terence Kennedy [ Wed Apr 24, 2024 4:33 pm ] |
Post subject: | Re: Archtop side tensioners |
Maybe some of the other archtop makers will chime in here but you might be addressing a problem that in reality does not exist. You also have to think about accessibility for repair or pickup placement in the already limited access provided by f holes. Is the guitar pictured one with a flat back and arched top? Carved or laminated? |
Author: | Alan Carruth [ Wed Apr 24, 2024 5:55 pm ] |
Terence Kennedy wrote: "..you might be addressing a problem that in reality does not exist." That's my opinion. So far as I can see, a top that sinks a lot over the 'medium' term is probably either too thin, badly shaped in terms of the arching, or has excessive break angle over the saddle producing a high down load. Spreading of the sides is not an issue that I can see, so putting in a 'collar tie' probably won't help. I've only been making them for about 40 years, so I can't say much about the long term from personal experience. |
Author: | Ken Nagy [ Wed Apr 24, 2024 7:02 pm ] |
My archtop ROSE. Once it did that it's been stable. It did raise a little more when I put stiffer strings one. But it hasn't moved at all since then |
Author: | Hesh [ Thu Apr 25, 2024 4:13 pm ] |
Beautiful work John. I agree with the others as a repair guy we frequently work on arch tops that are approaching a century old and never had this problem. Check out the work of Howard Klepper specifically his use of cylinder tops, flying buttresses and fully length CF suspensions. I have a feeling you will find it interesting even it if it is not technically an arch top. |
Author: | Honza [ Fri Apr 26, 2024 2:11 am ] |
Terence Kennedy wrote: Maybe some of the other archtop makers will chime in here but you might be addressing a problem that in reality does not exist. You also have to think about accessibility for repair or pickup placement in the already limited access provided by f holes. Is the guitar pictured one with a flat back and arched top? Carved or laminated? Hi Terence, yes flat back and carved top. It has a soundhole rather than f holes so access is a bit easier, albeit a very thin body (55mm) so still not that straightforward. It will be an archtop bass so for bass response I need to make the top as responsive as possible without it collapsing. So my thinking is to make sure that the dome is supported as much as possible by the sides. I have enough problems dealing with real problems building guitars, I really shouldn't create new ones. ![]() |
Author: | Honza [ Fri Apr 26, 2024 2:24 am ] |
Ken Nagy wrote: My archtop ROSE. Once it did that it's been stable. It did raise a little more when I put stiffer strings one. But it hasn't moved at all since then Hi Ken, was your assumption that this was caused by the rotating forces from the neck joint? I could see how that could potentially cause the top to rise. |
Author: | Honza [ Fri Apr 26, 2024 3:09 am ] |
Hesh wrote: Beautiful work John. I agree with the others as a repair guy we frequently work on arch tops that are approaching a century old and never had this problem. Check out the work of Howard Klepper specifically his use of cylinder tops, flying buttresses and fully length CF suspensions. I have a feeling you will find it interesting even it if it is not technically an arch top. Thanks Hesh, yes really interesting work from Howard Klepper. |
Author: | Ken Nagy [ Fri Apr 26, 2024 8:15 am ] |
Honza wrote: Ken Nagy wrote: My archtop ROSE. Once it did that it's been stable. It did raise a little more when I put stiffer strings one. But it hasn't moved at all since then Hi Ken, was your assumption that this was caused by the rotating forces from the neck joint? I could see how that could potentially cause the top to rise. Apparently MANY things are going on. The belly wood of the archtop is curly redwood, so, it might like to bend. I have some violins and violas that have risen, and the projection dropped. More than halve of them, including a cello haven't moved at all. So I don't have a clue of what to do to keep the neck block from rotating. I don't know why most have no problem, but others do. What is different? I don't think that it is just the neck bending. The belly can't rise too much if it isn't being squished by the north/south pull of the strings. Acoustic bass sounds like a cool thing. Bass lines are what I hear in most songs; at least older songs. The new stuff doesn't have bass, harmony, or even melody! I have really stiff Doug fir that I was thinking of making into a 12 string archtop with a low arch. But an acoustic bass might give about the same string load? A 5 or 6 string? |
Author: | Honza [ Sun Apr 28, 2024 12:13 pm ] |
Ken Nagy wrote: Honza wrote: Ken Nagy wrote: My archtop ROSE. Once it did that it's been stable. It did raise a little more when I put stiffer strings one. But it hasn't moved at all since then Hi Ken, was your assumption that this was caused by the rotating forces from the neck joint? I could see how that could potentially cause the top to rise. Apparently MANY things are going on. The belly wood of the archtop is curly redwood, so, it might like to bend. I have some violins and violas that have risen, and the projection dropped. More than halve of them, including a cello haven't moved at all. So I don't have a clue of what to do to keep the neck block from rotating. I don't know why most have no problem, but others do. What is different? I don't think that it is just the neck bending. The belly can't rise too much if it isn't being squished by the north/south pull of the strings. Acoustic bass sounds like a cool thing. Bass lines are what I hear in most songs; at least older songs. The new stuff doesn't have bass, harmony, or even melody! I have really stiff Doug fir that I was thinking of making into a 12 string archtop with a low arch. But an acoustic bass might give about the same string load? A 5 or 6 string? A light 4 string bass has very similar string tension to a medium strung 6 string. There are 5 and even 6 string basses in existance (Warwick Alien springs to mind) but from the online videos I've seen they sound pretty terrible when acoustic. A low B seems like a an impossible wish on an acoustic.... |
